My corridor is producing double cut and fill lines. When I look at the corridor in 3D I get cut in fills at an elevation of 0 and on the model.
How does this get fixed?
When cutting cross-sections the view is also impacted by this.
If you review the 3D model do you see any elements at a zero elevation? Maybe do an element selection and select all to see if there are any hidden elements there. Also what product and version number are you using?
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
I do have elements at 0. I am unsure why. I checked the template, nothing wrong there. I am using openroads SS10. It doesn't appear to me that there are any hidden elements. We are using the same templates on other portions of this project and this isn't occurring. Could this be a surface issue?
Do you have the 2d models referenced into the 3d as well? Xsections will draw everything in the 3d model including 2d references.
I do, thanks for the tip.
