When using the Place Conduit command the following error occurs and the command is closed.
Does anyone have a fix for this? It just started this morning, I haven't had issues in the past. I have tried:
I am using OpenRoads Designer CONNECT Edition - 2020 Release 1 Update 8 - Version 10.08.00.88
Thanks!
Same issue on our end with Update 10. Tried all the above fixes with no luck. Waiting for Bentley to respond to SR.
If you have tried creating a new DGN, using the Training and Examples workspace, and the Training-Metric (or Training Imperial) workspace, then using Place Node, and Place Conduit. If that causes the "Object reference not set" error, then:
Exit the software, and in Windows Explorer go to:
C:\Users\your user name\AppData\Local\Bentley\OpenRoadsDesigner\10.0.0\prefs\civil_commands
and delete the "SUBSURFACE CONNECTNODES.xml" file.
Now go back into the DGN you created earlier, and try Place Conduit again.
If it still doesn't work, then please raise a Service Request.
