When I go to survey-fieldbook-import-trimble link and pick a fieldbook, I immediately get a box that says "error occurred importing file". The help is useless - the complete help for trimble link is that the command allows you to import trimble .job files. That's it. Anyone know how to use the command? Is it looking for the .job file in a special double secret hidden location? Using the most current version of OSD. Thanks.
Hi David,
I believe this means you will need to try and download the Trimble Link Engine. Go to the following website to download/install the engine.
https://www.trimble.com/support_trl.aspx?Nav=Collection-27101&pt=Trimble%20Link%20Support
If you haven't already, you will also need to register to use the Trimble Link Engine. Once you've installed the engine, close out of OSD and reopen it. When you try to Import from Trimble Link, a new window should pop up asking for an authorization code. There will also be a link to a website where you will register and get the authorization code. I will place the link to that website below.
https://www.trimble.com/register-tls/
Once you register, you can copy/paste the authorization code in that window, and it should start working.
Jacob
Answer Verified By: David Silverman
Thanks - that works. We use Trimble Business Center and I would have thought that it would have been included in that install.
