ORD Vertical Alignment tools
I’m using the “Profile Line From Element”, “Tangent Profile Line From Element” in OpenRoads and looking for an option that I used to use in InRoads SS2.  When using this tool, I am prompted for the Start Point along a curve and then ORD calculates the tangent grade for me.  In several cases I know what tangent grade I need and want ORD to calculate the start station.  I can do the match and calculate the start station by hand to get the desired grade, but is there a way to change the input method to give ORD a grade instead of a Start Point?
