How to output ORD cross sections as per native format
Hi All
I am try to figure out if there are ways possible to output cross section in Openroads Designer as per the native / traditional layout we had in SS4. I.e output to one model view but with multiple sheets
From this output, our CAD team would then create drawings by simply xrefing this into a drawing file, move the boarder and 'clip' to show each individual sheet per drawing file. This would be done at a stage where our models are frozen.
The attached image, is an example of what we produced in SS4, but i have removed the annotation for clarity.
If there are any workflows or workarounds that will be great - As a standard our cross section are cut every 20m, so in terms of how many cross sections drawings we need for a project could be not many to a LOT :)
