I'm developing some grading sheets in ORD Connect. In V8i I could use the tracking tool and with one click get the Station, Offset, and Elevation of the Surface I needed to put into a call out. Or, I could use the InRoads drafting tools and get the same 3 data fields. Then I would use the Two Point Slope tool in InRoads to get and annotate the slope between two points.
Currently the only way I can find to get the elevation of the surface and the slope is by using the Analyze Between Points (gives me the elevations of both points and the slope between them), and then taking a screen shot of the data so that I can then select the edit tool to manually add the text into a callout.
There has got to be an easier way. I have tried using the Place Label tool, but all I can get out of it is Station and Offset, not Surface Elevation - it just stays zero'd.
What I want is a Place Label option that spits out the Station, Offset, and Elevation (surface). And, another one that annotates the slope between two points.
Is there such a thing in ORD Connect?
Thanks in advance.
Yes, we have video demonstration for you to annotate the cross section and profile by using the Text favorites for station ,offset and elevation , Pleas follow the below link of our YouTube channel which will guide to resolve your issue ,
www.youtube.com/watch
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Thank you for the response, but this didn't work.
I tried using the "Point Elevation" within the "Field Type": "OpenRoads Cross Section Annotation Fields" option.
I'm not working in a cross section view, but a plan view. Not sure if that's why it didn't work.
Also, I want one call out that generates the Station, Offset, and Elevation (of the surface).
Please the image for an example of they type of callout I'm trying to get. You'll notice one of the callouts has an elevation of 0.00 (the others I used the "Label Terrain Spots" tool to get the elevation and copy it into the callout text.
Side note. Why is it that I can't active a Terrain model while in a Sheet or Drawing Model? Is this causing my issue with getting elevation data via the "Place Label Settings" tool?
Thanks again for your help.
The same question as me with my boss pls give me offset elevation so am confused what I can do if anyone have an idea pls share me
