Good day Everyone,
In the last few days, I noticed that the preferences that the company I work for has disappeared and no one is able to see them anymore, leaving only a default preference (see image). I'm not all that familiar on how Geopak saves and stores its preferences for XS, however, given that everyone at my workplace who uses geopak are able to see the preferences means its somewhere on our server. Any insight on how to reestablish the preferences would be appreciated. My other issue is that whenever i hit the Annotate Cross Section button I receive an Error 2753 popup that prevents me from doing anything. If anyone can provided any kind of advice, I would be appreciative.
The preferences are stored in an XIN file, and the location of the XIN is called by the "CIVIL_XIN_FILE" configuration variable.
To workaround the installer error, you will have to run GEOPAK as administrator. (Either through the right-click menu on the icon, or the Compatibility tab on the icon Properties)
Answer Verified By: David Palacios
