I've imported a .alg file or .xml into ConceptStation from the geometry from OpenRoads Designer or previous versions, when placed, everything looks perfect, horizontal and vertical.
When designing a ramp connection, the vertical alignment seems so off at other given point, even though the alignments have the same elevation and mostly intersecting (please see attached images).
The problem is not where the ramp is connected as the software creates the intersection and everything, but the rest of the road loses the vertical profile to something way off.
Any thoughts on this problem?
Would you send me your files? I will see if I can reproduce the issue and see if I can figure out a way to fix it. You can use the link below to get your files to me.
https://bentley.sharefile.com/r-r10b782b320142bd9
Jacob
Jacob,
Just uploaded for you, please take a look, the software should at least lock the horizontal and vertical alignment, even if that'd result in the creation of a new PI or something.
If it is some limitation (for now or forever), I'd like some workflow, maybe new enhancements (like table input values of the alignment).
I'll look forward to your answer.
Kim
Would you mind uploading your files again? I received an email informing me that you uploaded your files, but they weren't there. I created a new folder in a different location, so try it again with the link below.
https://bentley.sharefile.com/r-r0c2b3cb6ce34229b
Just did, please take a look and try to replicate the issue, I sent you the .alg file, if you open on OpenRoads Designer, you'll see that when importing, the roads don't seem to be correct at some points.
And when you place a Ramp Connection, the rest of the vertical alignment changes altogether.
I just created something out of an old alternative and was testing to see the results, but ConceptStation has to improve a few more features (I'd ask for constraints of the parameters, even if the phasing is at conceptual design).
Maybe I misunderstood, but it seems like I observed something different than you. When I imported the .alg file into ORD, the alignments looked good. This was not the case when I tried it in ConceptStation. The horizontal always imported correctly but the vertical did not. When I placed Ramp Connections on the roads that imported correctly, everything seemed to work fine. Only the necessary parts of the vertical alignment changed. When I tried on the roads that didn't import correctly, the results didn't look good, but they weren't necessarily incorrect based on the messed up alignments. Did you observe any of this?
