i recently started getting this error when i try using the function keys for a new view. any solutions?
Have you written a new VBA routine to assign to the function keys? Is it loaded?
it should be, it was working earlier in the day but for some reason it stop working
Did you stop and restart ORD? Is the VBA project auto-loaded?
i check the VBA setting in the variable config and the paths were broken like you mentation . thank you
Answer Verified By: Mark Marnell
I have this error too. Where are the VBA Settings to check the paths?
