Vertical Profile Does Not Complete
I'm trying to create a graded area around a pad. I create the horizontal geometry (square) and then use Complex Geometry to unify the lines into a single element. I create the concrete pad first, without issues, and the vertical profile is generated again, without any problems. However, I want to create the vertical profile of the surrounding grade by reference to the pad at a -1.00% slope. I used "Profile By Slope from Element." After completing the prompts, the profile of the grade is generated but there is always a "piece" of the geometry left out of the vertical profile, while no apparent break in the horizontal profile exists.
Parents Reply
  • The horizontal geometry, are all the straights connected at the corners?
    When doing something similar with ponds, I found vertical design, corridors and linear templates would not close correctly and meant I was missing the quadrant.
    To get rid of this I started a straight half way along where I wanted a full straight. Then completed the shape and returned with the other half of the original straight. Making sure that the bearing is the same as my first straight.
    Once complexed everything worked as expected.
    Chris
    AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
    Associate Director – Digital
    OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
    Civil 3D 2023 | Dynamo | Navisworks Manage
    PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
    Speckle | BIMVision | Revizto | Solibri
