Create Cross Sections only shows terrains and not components
I can't figure out why I can't get the components to show up for a corridor file. In the dynamic cross section viewer, it will display everything as you would expect. When I use the "Create Cross Sections" tool, it only shows the terrains that I have created and none of the components from the corridor. I have split up the project into four different corridor files and only one of the four is having this issue and I am not seeing any differences between this one and the other three.
Power GEOPAK v8.11.9.832
