Hi
What would be the best way to modify or editing a existing horizontal and vertical (complex) geometry.
I need to add new lines and arcs to existing geometry (both horizontal and vertical) where i already have created a corridor and civil cell intersection as well as profiles and I want to avoid doing it all again.
I am using OpenRoads Designer 10.08.01.33
If you are adding new lines and arcs to existing geometry, I recommend creating your lines/arcs and using the Complex Geometry tools. You can find them in the Horizontal and Vertical sections of the Geometry tab of the OpenRoads Modeling workflow. You can also use the Complex Redefine tool found in the Common Tools section in the same place. Since you will have changed it, you will need to reprocess/update anything that depends on the geometry, like corridors. I added below a link to a potentially helpful LEARNserver course and a similar forum post.
https://learn.bentley.com/app/Public/ViewLearningPathWithMasterCourseExpanded?lpId=110831&mcId=103290
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/196507/adding-new-elements-to-existing-geometry
Jacob
Answer Verified By: Sigfus Jonsson
Thanks Jacob, that was exactly what i was looking for :-)
