Dear All,
While assigning Superelevation to corridor is it necessary to apply superelevation flag for all Layers?
Only the features in the template that are used when applying superelevation - in the example below, only the centre line and two carriageway edges - need to be flagged. The other features will move depending on the constraints. (I am not sure what you mean by 'Layers'.)
Layers mean WMM, GSB etc.
But for 4 Lane with Divided highway how to give flag points?
kbb9327
Edit the template - that is where you assign the superelevation flag. See the image above.
Hello ,
I think you forgot to upload image.
Please share.
No - I was referring to the image above i.e. in my first post. You assign the superelevation flag the same way in a divided highway as in a single highway.
