Hi all,
I have two questions regarding Cross sections.
1. Yes - if the sheet is wide enough to fit in more than one column, the extra column(s) will be added.
2. There are 4 configuration variables that are used. They are explained in the configuration file ('UK Standards.cfg' in my case).
CIVIL_CROSSSECTION_RT_TO_LT_SPACING = 0.005CIVIL_CROSSSECTION_TOP_TO_BOT_SPACING = 0.030CIVIL_CROSSSECTION_SIDE_MARGIN = 0.025CIVIL_CROSSSECTION_TOP_MARGIN = 0.007
Thanks Marks,
After few trail runs this is the results.
You may need to play with those numerical values if the output isn't quite what you wanted to see.
MaryB
If you do not need the sections to be so wide, you can change the left and right offsets when cutting the sections (in my case they default to 35m). This does depend on what you are trying to show in the sections, of course.
I´m having trouble displaying the template components in the cross section. Maybe you can help me with that?
