I am using ConceptStation Connect Edition. I had my road completed with no issues, but then we decided to change this one section that has ramps, bridges, etc. so I was deleting a lot of stuff. Then I ran into a problem so I decided to "undo" all of my deletes. I think it went on overload cause it just crashed. Now whenever I open this file and zoom into that area, as soon as I click onto one of the sections that had been undone, the entire program just crashes and closes. I tried removing the journal file as well as moving and renaming to another location but same result. I'm worried I am going to have to start all over which I do not want since this is 50 miles of a highway. I would like to redo this entire area but I will need to delete the partially deleted items but now I can't select anything without it crashing. See partially deleted picture attached. Any help would be most appreciated!!!
Hi Simon,
I am also experiencing the same issue with my file. I tried using the Fence selection to delete the items in the region I suspect caused the error. After deleting, the file still crashes whenever I use the VISUALIZE tool. I tried using the backup files, but all of them are also now having the same error. Could you please suggest any other workarounds? Thanks.
