Cross Section Cells Height & Base Elevation Glitch
When creating corridor cross-sections, some of the XS's will display correctly, while others have a base elevation at -5 and show up very tall. When using the Cross Section Sheet Composition, these incorrect ones are not even found when laying out the sheets. Is there a fix for this glitch?
The screenshot is zoomed out, but the 2 on the left are the incorrect ones while the 2 on the right work as they are meant to.
TIA for the help
