Hi, I have drawn the baseline in a project and properly stationed it, it lines up well with the respective state plane coordinate system, however is there a tool or printout where I can enter the locat coordinate (station and offset) and recieve the respective state palne coordinate?
Does your drawing have a state plane geographic coordinate system attached? Does your drawing have any geographic coordinate system attached? Do you have a state plane coordinate system available?
You should be able to generate a Report of your geometry that can give both stations & offsets, and Northings & Eastings for your coordinate system.
MaryB
MaryB, yes The design file is set up for Illinois State playing east, your answer about The reports is what I’m asking, how do I generate that report? Thanks
I'm still learning OpenRoads myself, but I know that the report "style sheets" are in XML format, so you should be able to create a report "template" for whatever data you need. I was able to do that for the InRoads reporting tool, and the ORD looks very similar.
Hopefully someone who has more experience will be along shortly.
Hey, Ms B!!
New company, new rules!
I am now using GEOPAK 08.11.09.918 SS10. I need to set up a State Plane Zone as the survey team is working in C3D.I have done it in C3D, but not in GEOPAK. How do I do this?
Thanks!
