Hello everyone,
Longtime AutoCAD user here who this past week decided to give OpenSite a whirl. I am a Microstation/OpenSite Designer noob.
Background:
I already have a working TIN surface generated in Civil 3D and I want to import into or recreate this surface in OpenSite Designer as I want to use the grading automation feature.
Questions:
1) What is the easiest way to do this? A Internet search reveals there is no easy solution.
2) Within OpenSite, when selecting "Create Terrain from Ascii file" and then Edit Text Import Settings File then the columns tab, I do not see column headings for point # or description. These do exist within the csv file.
Thank you in advance for any help. I know I have a lot of learning so any recommended Bentley Learn training videos are also appreciated.
Tom
I have no idea what format the Civil3D surface is stored in, so my idea would be to export the surface from Civil3D to LandXML - and import the LandXML file to OpenSite,
