For some reason when I place civil plan boundaries each boundary has a different length which is less then the predefined length of the drawing seed. It appears that the drawing seed length is measured along the alignment. This creates a situation where every sheet model has a certain amount of white space on the right side of the frame.
Am I missing something here?
Here is an example of an A0 sheet model. Notice the unused space on the right side even though the drawing boundary handles are positioned correctly.
The length is calculated using the alignment as the baseline - so that is why you are getting that space. If that is not what you want, please submit a service request to the help desk.
Answer Verified By: Benzi Papo
I found this line in the ORD documentation that hints at a "By Length" setting. Apparently it has been removed.
how to eliminate the space on the right side? I have the same question with you!
As I said previously, and the documentation shown above states - the length is measured along the path element. This means you will get a gap - please submit a Service Request to get this flagged.
