I have a corridor with multiple template drops and for some reason the corridor boundary disappeared and I am unable to change the design stage. All i can see is the template drop start and end lines. Is there another way to change the design stage for a corridor?
In another corridor file, which I have because of the length of the project, the boundary does display but when I click on the properties I get these weird properties. Does anyone know how to fix either of these issues?
I'm working with PowerGeokPak V8i SS4
Chris, I have seen some similar type behavior for the boundary (not the properties) and have found that running the corridor reattach on the corridor has straightened some of it out. May be worth a try.
Steve
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
So that helps the boundary show up, but when I click the quick properties to change the design stage I get what you see in the second picture I originally posted. A bunch of lines that say "Is True: False"
Halfway is a good start I suppose. I guess a question on the properties,do other users see the same? If not, it may be related to user preferences, you could try clearing those.
Tried changing them to true. Not all of them are able to be changed. Unfortunately they didn't change anything
