I’ve created a new feature definition for an existing pavement terrain- as per our standards, the existing pavement terrain will be shown as a custom line style that is to be included with out cross section.
From the below, I am having some trouble displaying this line style within the cross section (cyan colour line), The line style lib is attached to the files and can draw lines using the line style. are there any tips on why I cant display the line style within the cross section? Using the ustn standard line style (1-7) work great and these are shown when i update the element template, however im getting no luck with displaying the custom line 'SECT Pavement)
Is this the issue where the dash-gap pattern sometimes displays and other times looks solid? There is a fix that is related to the depth of the cross section slice and I believe a tool to apply it to all sections. It might be listed in the readme, but I am not sure.
Hej,
I am not sure if this is the same issue. Neither I found info on a tool to fix this depth of XS. Basically this is my line style:
and it is not honored for XS, built- in line styles, dashed, dsh-dot, etc are displayed just fine.
I will appreciate any tip to fix it, the info on a tool you mentioned would be valuable.
Thanks in advance.
Adam
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
Have you created the custom line style in ORD? I have come across some issues with line style editor of ORD.
Have you tried creating the custom line style in microstation or SS4 and then import the rsc file in ORD?
Try to import and not open the rsc file as it might corrupt you custom line style. Hopefully this will solve your issue.
