Hello all,
I assigned Superelevation to corridor but when i generate report level difference not showing as per superelevation. i created cross section where superelevation has been seen.
i am not getting where it went wrong.
What report are you trying to use? You can see that the road is superelevated, so that would imply your report is not working, or you are using the wrong report.
i am using station base report. and it will ask for locating offset element.
attaching file.orf _files.rarorf .xls
kbb9327
Select the StationBaseCrossSlope.xsl report - that may be more suitable
I did StationBaseCrossSlope.xsl report, but result is same.Cross slope_files.rar
Have you tried amending the XSL file to reformat the data to get what you want?
