Let's say one has created plan and profile sheets or cross sections with OpenRoads Designer. There are dozens or, perhaps, hundreds of them. Now one needs to turn on or off a level or two in each model. OpenRoads Level Display Batch Processor to the rescue!
Because OpenRoads Designer creates drawings and sheets in a very structured, programmatic way, OpenRoads Level Display Batch Processor can "copy" level display settings from model to model. Simply setup the active model the way one wants and run the VBA macro.
If all models are in the same file, use the Active File option. If the models are in many files, pre-populate the Files list using the Browse File and Browse Folder options.
The macro can also be used to turn the display of reference attachments on or off; use the Toggle Reference Attachment Display option.
There are also options to exclude or include models using filter strings.
Note: This macro contains no OpenRoads Designer specific code. However, to function properly, it does require that attachments be set up with similar names, nesting depth, etc.
Download the macro file here: https://communities.bentley.com/products/road___site_design/m/road_and_site_design_gallery/274493/download
Perhaps you should move this to the OpenRoads discussion board? Or expand on the discussion to explain in more Microstation-generic terms?
MaryB
It'll be posted there later today Mary. :)
Tim great tool. Any chance you can get it to work with files stored on ProjectWise
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Thanks Chris. ProjectWise integration is on the to-do list but I'm not a ProjectWise user, which makes it difficult. I would say it's not imminent but may be released in the future.
Good Morning, in which folder do I install this Batch processor?
