I was wondering - has anyone came up on how to show (horizontal) geometry points with elevation on geometry profile view?
OpenRoads gives us possibility to place points via geometry->horizontal->Point.
Those points have Feature definiton, elevation and rotation defined.
Point's feature definition uses Point feature symbology which clearly gives us possibility to show point differently in Plan, Profile and 3D view:
When point has defined Plan symbology as a cell - that cell shows on plan view when point is placed - it works okay.
When that point also has defined 3D symbology as a cell and has set elevation - that cell shows on 3D view - it also works okay.
It also has different annotation groups for Plan and Profile points.
My point also has defined Profile symbology as a cell - I would expect to see that cell on my profile view...
But I've been trying to show that point on geometry profile and I simply have no idea how to achieve that.
3D cut works only with 3D cell defined - but in my situation I do not need to show that feature in my 3D model - I just need my Profile cell shown on profile view.
Is this even possible or Bentley gives us another feature which is not completely functional (I wouldn't be surprised)?
In this particular situation I want to show road exits on profile view with placing auxiliary points on plan view in places of those exits. Elevation should be inherited from alignment profile.
Or maybe there is another way of marking exits automatically on profiles?
I'd be glad for any help or suggestions.
Jakub
The ability to project COGO 'Points' to a profile has been requested and Bentley development is working on this request. The profile view is a planar display (slice) and does not currently have a way to create a projection bandwidth to get information from an offset placement to display in the view.
The request number is:
Enhancement 985041: Project Points to Profile (Event Points)
I have created a service request for you through Technical Support and linked this enhancement request to the SR for reference.
The only ability to display a 'point' in a profile is through the Profile Intersection Point which requires a linear 3D element which crosses the plane of the profile.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/32235/video-profile-intersection-point
Q1. Is this problem solved and enhancement made in the software?
Q2. Also is it possible to at least have the points annotated in the final profile drawings after the drawing production stage? If yes, kindly share the detailed procedure for the same. Thanks in advance.
we need this capability as well! When we place points along an element, we need those points to show up in profile and 3D view but currently the points dont realize they are snapped to a 3D element - they only show an X &Y in their properties.
Is this solved now? I can't seem to work out how to show profile representation of placed items (3d representation of points) in the profile view. This is needed to build the profile correctly to attach to certain items.
This has been migrated to our new IDEAS portal. Here is a link to the idea so you can track the progress of this addition to the product.
https://bentleysystems1.aha.io/ideas/ideas/BCI-I-105?active_tab=portals
Answer Verified By: Chris Key
