I have been asked to add stormCad data to my openroads model .I created a new file and under subsurface utility there is a project/import/import *.stsw tab. When I do that it goes thru the process of creating the utility model but when it finishes I get the message "import into default failed". I have no experience with stormCad so looking for some explanation of what is missing that is causing the import to fail or a link that has more information (or both!).
Thanks for your help,
Brian
Unfortunately the Drainge and utilities is not backwards compatible. StormCad has no concept of Feature Definition so you will need to assign Feature Defs to the Structures and the Conduits.
The best you can do from what I see in the picture is reconnect the pipes to the proper structures once you have set all the appropriate feature defs. It looks like the connectivity is incorrect.
If you have ORD you can import the file into there to check the connectivity of the pipes
