The menu bar of InRoads SS4 disappeared, how to reload it? Thank you in advance.
Please try the following, on the InRoads dialog box, right click on the location of menu bar, and select "Customize" from the tool bars check mark the option "Menu Bar". Hope this helps.
Even the InRoads dialog can't be found. Only the InRoads Commands tool bar loaded.
Right click and hold in a view. There will be an "Explorer Show/Hide" menu item that toggles its display.
It may also be listed in the InRoads Tools menu that is inserted into MicroStation's menus.
