Every time I try to annotate my cross section I get this error and cross section don't get annotated. Any solution?
What software are you using?
MX Road SS4
Santosh Rai, EngTech MICE, ACP, BQT
Senior Designer - Highways
I have never seen that error. How are you trying to annotate the cross sections? Have you tried using an input file to do the annotation? I am assuming that you have the cross section sets in a model.
I am using graphical method for annotation. Can you help me with input file? My section are in Micro station view.
Your sections are stored in a MX model - you may have a representation of them in a MicroStation view.
I am not able to give you a training course in Linemode - but I will point you to the file 'simp105.inp' - stored in the 'C:\Program Files (x86)\Bentley\MX V8i (SELECTSeries 4)\MX\MFW\UK_tut' folder on my laptop. Assuming there is a section set called 'R' and another for 'G', the lines from 1288 to 1348 will draw both sections, and annotate them.
You just need to work through each line and read the Hep file for each option to see what is being done.
