After creating and finishing a project using ConceptStation, I exported the project's elements to be used into ORD. The first time I tried to import the .ird I got the message that I had not imported the horizontal and vertical geometry beforehand. Therefore, after importing what was asked I got and error message stating that "Unexpected Error Occurred. Command Exited. Error Details: Line 1, position 1.". I tried to uninstall and reinstalled the software on the 10.08.01.33, but the error keeps coming up. I did the same process using the PowerCivil for Brazil Version V08.11.07.494 and it worked perfectly. I really need to hand in this project today and will be very disappointed if I'm not able to use the ORD to finish this.
We were able to import your IRD with a newer version of ORD, I will contact you directly at your Gmail address.
