I created a Complex vertical profile that is 6800 feet long. I created the individual components, curves, lines, etc.... Then combined it
Into a complex profile. When I try to use the table editor to edit the profile, the editor ignores the vertical curves and associated VPI’s
See graphic below. The preview shows a straight dashed line from the PVC to the PVT, eliminating the PI and curve if I hit apply.
If I drop and re-complex the vertical alignment, I get the same result. The editor seems to work ok on shorter alignments. Any ideas?
John Ludwig
Would you mind saving the settings with the problem profile open then sending the dgn to this link https://bentley.sharefile.com/r-r175b5d20fc341558 so I can have a look?
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Hi, any solutions for this one? I'm having the exact same problem.
Matt
