How do I label element Northing, Easting, Elevation in referenced files?
I am trying to figure out how I can annotate a drawing for a site layout within OpenRoads designer connect edition.
I have been able to "Place Label" with a text favorite that will appropriately label northing, easting, and elevation of elements that are live in the file (not referenced in) using the following text favorite:
N = Linear Annotation.Point Y
E = Linear Annotation.Point X
El = Linear Annotation.Point Profile Projected Elevation
However the elevation does not label on any elements that are referenced in, it comes through as 0.00'. Is there a better way to be doing this?
Because I have a terrain from these elements I can delete out the elevation and label the terrain elevation using terrain -> "label terrain spot" but that doesn't make one nice label with all the information.
Otherwise I would have to put all of my labels in the design file??? seems to defeat the purpose of having design and sheet files separate.
Thanks for the help,
Levi
