I am clipping a corridor to model a curbed island. It works fine except along one single line on each area that is clipped, circled in yellow.
Here is a closeup of what is happening in cross section. The shape is not closed and has vertical stub lines.
Any idea what is happening and how to fix this?
Thank you,
Dennis
Hi Dennis,
I have noticed this quite a bit as well. I suggest you put a ticket in to see if it can get logged as a defect.
Mark
