Hello,Recently I have a problem with import * .las point clouds. The cloud is created in Afisoft and works fine in other software. After the * .las to * .pod conversion, the point cloud becomes distorted and deformed. The cloud has got a lot of false points. Previously, everything worked fine. Importing * .xyz to * .pod used to give good results. What is the problem? I use Bentley V8i PowerSurvey SS10 / SS10 PowerDraft 08.11.09.916.
*.pod: https://drive.google.com/file/d/1qiIxDaT2E5yX6mfDMWU2Y0nLs4ti-qHJ/view?usp=sharing
*.las: drive.google.com/.../view
I converted the las to pod in OpenRoads Designer 2020R2. Can you see if it looks any better with this file? https://bentley.sharefile.com/d-s546f448c09e4e198
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
