Hi All
Using Openroads, is there a way to view grided values of a delta surface? in SS2, this was pretty easy in terms of generating an isopach and then viewing the values in text format on a grid.
The thematic height and updates to the view display is really cool in ORD, but ideally a 'number' format will be a lot easier to present the detail to the client - This would be more for the civil-type projects like parking lots, building plateau ect
Cheers
John
The way I found to get the grid annotated is described in the attached PDF. Once you know the steps, it is quickly done. Note that the PDF is describing how to annotate a 'normal' terrain, but that terrain could be a 'delta' terrain - same principles.
PDF
Thank you for your reply. This is certainly what we were after, would there be an enhancment for more dynamically driven text output in the future for ORD?
Answer Verified By: Mark Marnell
I am not part of the development team, but I believe there are enhancements in place.
