I am trying to set up ORD on our server. What config file do I change? The one that was copied over to the server or the original one in ORD CE.
This wiki should walk you through the process.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/42832/configuring-an-openroads-designer-workspace-on-a-server-and-on-projectwise
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Awesome, thanks!
Okay I just went over that pdf. This only addresses the WorkSpaceSet config file. What about the ConfigurationSetup file?
Paul, I think you are looking for Method 2 in the documentation from the sounds of it. I don't run with that set up, but in my testing if I recall right, you adjust the local CongifurationSetup.cfg file and remove the one on the server.
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022 / 2024
I got it to work. I was just over thinking it, that is what happens when they get a C3D guy to set up Bentley programs. Thanks for the assistance. I have a feeling this will not be last time yall will hear from me. Until then have a great day!
