I'm running into a two issues.
First, my ROW Lines appear in the Cross Section Viewer (see image below)
However, whenever I go about to create the XS for my sheets, everything but the ROW lines are displaying (see image below)
Weird thing is, they happen to populate on my XS when I ran the sections in a previous day.
My second issues is in regards to portions of my template drop not appearing in the model. I have this ditch section I modeled however the backslopes seem to have mysteriously disappear also when I run the sections they are not there. See image below to see how it should look like.
However the portion circle tends to dissapear. Not sure if its a graphical issue or not as it seems to reappear when i restart my computer.
At first I thought the that portion of the template was set to 'do not construct' however the option is not marked
Any assistance or advice will be very appreciated.
