Hi All,I'm trying to use the Conic Slope function at the bottom of a retaining wall that is below existing ground. I can't seem to get the function to work in a cut scenario, it works fine when I force it above the existing surface (making it a fill slope).
I've tried changing the slopes to a negative value but this does not help. I'm using OpenRoads 10.08.01.33
Any help would be appreciated.
Here is link to a wiki article that explains the Create Conic Slope tool. Let me know if it helps.
communities.bentley.com/.../video-create-conic-slope-tool-in-openroads-designer
