I am using Power Geopak SS10 and my active Feature definitions are not showing in Project Explore in both Civil Standards and Utility Model tabs.
All my pipes and nodes are showing in the drawing but they disappeared from Project explorer.
Please search this forum. This question comes up fairly frequently, and has been answered many times.
MaryB
I have not made any changes in the feature definitions file, the configuration variable is pointing to the right dgnlib file location. Upgrading to ORD is not an option because the client wants the file in Geopak.
My problem happened when I turned off some of the features in Project Explorer and continued using the file. Now I need all the features to be turned on, but project explorer is not displaying any feature. When I checked Flex Table, all my features are there and I am able to select them but I cannot see them in the drawing anymore because they were turned off in Project Explorer. I have this problem in only one file. The other one is working fine.
Did I accidental changed some settings in the file?
My apologies - I can't find the threads I am thinking about either. I'm sure there's something...but if neither of us can find it, that doesn't help. Besides, those discussions are usually that NONE of the feature definitions show up.
Is this what you are talking about: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/20953/feature-definition-check-boxes?
You can also try closing Project Explorer, restarting MicroStation and reopening Project Explorer. SS4/SS10 are a little more buggy than ORD (now) and I have seen stranger things than that.
Something else to try is https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/15923/geopak-resource-files-how-to-remove-them-and-why
old RSC files can cause all sorts of weird, unexplained behavior.
Yes, I am talking about the check-boxes. They are not shown.
I deleted the old rsc files and it did not solve the problem.
