Hi. I am using Geopak version 08.11.09.878.
Using Design and Computation Manager, I need to quantify existing utilities.
For that, I need a .gpk file, which is associated with the alignment of the road.
We received .xml file that is associated with the alignment.
How can I create .gpk file from this .xml file?
Yoko
I presume the .XML is a LandXML file if it contains information on the alignment. You should be able to import the LandXML file into a design file (Under General Geometry) and then export to a .GPK.
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
Answer Verified By: Yoko
Thank you, Steven.
