Hi!
I have looked on the video Create XS Sheet with End Area Volumes Annotation on the Wiki-page and I have some questions.
I have now done a little test-project with rock.How do I get that value to show in the table in the cross sections?And all components for the road we could get in the table i SS4, I don´t see any Annotation Definitions for them?
I have run the Create Cut Fill Volumes and get meshes for fill, cut(earthwork) and rock (as substrata).
Picture from SS4:(excuse some text in swedish)
Regards Håkan
Which software are you using now? You mention SS4, but then you show an image that looks like exactly what you are asking for.
If you are in SS4, what else do you want to see?If you aren't using SS4, what are you using? Please give us the version number, because there have been several releases and many changes over that time.
MaryB
Microstation 08.11.09.919Power GeoPak 08.11.09.918Power InRoads 08.11.09.918
Sorry!I´m trying to config OpenRail Designer, orld10080133en./Håkan
OK, hopefully one of the OpenRail people will be along shortly. I don't have any experience with that, and there may be program specific issues I'm not aware of.
But I know there are folks here who use it. Hopefully they can help you.
I would like to know how to do this as well in OpenRoads Designer. Is there a way to add specific component end area volumes to the cross sections?
As quickly mentioned in the video, there is a cell that contains text values. The XML snippets from the End Area Report are stored with the Named Boundaries, and are written to the cell with the Annotation Group.
Have you watched this video? - https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/41680/video-earthwork-xs-sheet-annotation
This one is more of an overview. https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/42992/video-create-xs-sheets-with-end-area-volumes-annotation
EDIT - However, the Text Favorite dialog does not allow you to select any component end areas/volumes.
