We are having issues with only a certain number of points are being loaded in to the Text Import Wizard, not all points in the survey data-it's only loading 30 points. After looking at several videos and scouring the internet, I've noticed that there is an option for "range", however, I do not have that option. Have you seen this before? My thought is there may be a Microsoft add-in that is missing and is restricting the full usage of the product. I've tried this on brand new installs of SS10. Any assistance is appreciated.
Thank you,
Jennifer Mullins
For me, after processing the data, it still brought in all the points. The "30" shown were just a preview to get the columns designated, a preview only. It should still bring in you 279 points if you go through the steps.
Thanks I was able to figure this out. You are right about the preview. My issue was that a column had the same name such as CL, CL, CL and I had to allow ORD to overwrite with a new a name such as CL1, CL2, CL3.
