Currently, it is possible to install and run only one version of OpenRoads (or any CONNECT product AFAIK).But different versions of ORD have somewhat different schema. Older versions cannot run design created with newer versions, and there is no way to save a newer version back to an older version.
This is going to be a BIG problem as more and more DOTs come online with their ORD conversion. I can see myself coming to a point where Indiana would only run on one version, Ohio will only accept a different version, and Colorado may run on another version entirely. Never mind partnering with other firms, and getting data in whatever version they run.
It is not realistic to believe that every major client in the world will be running the exact same version of OpenRoads at the same time.
I don't even know how firms are supposed to manage this.Are we supposed to keep a library of laptops lying around idle, for working on projects with THAT version, and others sitting around for the projects with THIS version?I've seen some mention of "virtual machines" but that sounds like a lot of IT overhead, which would be crippling to smaller firms. It may not even be practical for larger firms to do on a company-wide basis.
Lack of backwards compatibility paired with the inability to run different versions in parallel is going to hamstring production with multiple clients and multiple partners.What is Bentley doing to address this problem?
Agreed
