PDF
I am trying to import the attached alignment and the software keeps shutting down on me. I've imported other alignment that aren't quite as curvy without any issues. HELP!!
Import how? Into which software package/version? What tools/process are you using?
MaryB
Mary-I got sidetracked on another project and I'm just now getting back into this. I am using Power InRoads 08.11.09.878 and MicroStation 08.11.09.878. I am using the Import Geometry icon under the General Geometry tab. Would appreciate any suggestions you have. Thanks!!
I wonder if there isn't some kind of disconnect or non-tangential portion? Depending how the original data was generated, it's possible there's some small geometry inconsistency that the import is rejecting.
I checked the integrity in the native alg file and all appears to be ok. In order to get out of this rut and make progress, I'm splitting the alignment into 3 sections. Thank you!
I've done that too...SS4 is a bit buggy, and things don't always work quite the way they should. Whatever gets the job done!
