When using Field book Survey you can import from graphics (linear and points) to the field book. I noticed that different lines and points get sorted in different survey feature category.
How do you define this classification?
Also, all the different lines and points get the Terrain Model Attribute "Do not include" is there a way to set this to "Breakline" or any other automaticaly, so that when using the import from graphics thing get populated the right way?
When you refer to a different survey feature category, are you talking about different Survey Feature Definitions? The graphics should have an appropriate Survey Feature Definition assigned so it can be associated when imported to the Field Book.
There is a recent defect with regards to the Terrain Model attribute not coming from the Feature Definition but always getting assigned as 'Do Not Include'. Development is aware of the issue and that number is Defect 1088723
Here is a good video on utilizing the Import Survey data and some of the options associated to it. He doesn't cover the import from graphics but it does go through some of the options, codes, etc that may be helpful: https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/37564/video-example-workflow-to-import-survey-data
