Hi all,
Is anyone else having issues with the ORD 3D Drive through Tool publishing to the Microstation Animation Producer? It doesnt give me any errors, but I see no sign of it in the Animation producer.
My ultimate goal is to use the Drive Through tool to create an alignment based drivethrough for export to LumenRT. I am using ORD 2020 Release 2.
Mark
It's not working since many versions, your better with putting a car in LumenRT, asign the path that you want, then link the camera to this car in LumenRT.
Thanks Jeremie, has this been reported yet?
The issue is that LumenRT requires me to manually place a path, while I'd like to use one based on an alignment. I don't think you can do a path based on an line in LumenRT?
I'm not sure it has been reported (I don't have time to report all the bugs that I find) I tought the microstation camera path was exported to LumenRT?
What I mean is I think you have to export a Camera path base on your alignement, or rather an offset of your alignement, to LumenRT
I've found the defect in the backlog:
