There does not seem to be a tool to create a roundabout. Can I treat the central roundabout as a circular road with multiple junctions.
Is this similar to Stockdale method of Roundabout Design ?
MX had the 'Associate Alignment' tool that helped in Stockdale design - OpenRoads Designer does not have that tool, but you can still use that technique to design a roundabout "using the alignment tools" - to quote Martin.
Stephen Guile - in answer to your original questions - yes, you could do it that way if you wanted to.
Answer Verified By: Stephen Guile
Thanks Mark. Is there any video reference for the doing Stockdale method design in MX with 'Associate Alignment'. It will be of great help.
Ashok - not that I know of.
