I have a corridor that I use civil cells for driveways and Tee intersections at both ends. I need to cut cross section at centerline of each driveway. Also I like to see my cross slopes at both ends of my corridor where I have my T intersection civil Cells. In SS4 I was able to select the civil cell terrain in my filters but in OpenRoads designer I am not sure how to accomplish this task since you could only pick template points and civil cells only have surface templates. Any help would be much appreciated. Thanks,
Following, I'm in the same boat!
was this ever resolved? having a similar issue!
No I still have the same issue. Very frustrating!
Create a profile of your drive at the same scale as your sections. Reference that profile drawing into your mainline sections.
This wouldn't cooperate/synch with a "smart" model but, end of the day could get the job done. Will ORD annotation pick up points on the referenced drive model? Or do you have to manually annotate the drive model as well?
