Color Coded Elevations Export
I asked before if it is possible to create color coded elevation in ORD. It was suggested to use the Display Style as Thematic.Height, which works quite good, but in PowerCivil I was also able to export the file as a dwg. I wonder if there is another workaround this.
Thank you
