Is there a way to get a report of the Survey Feature Definitions from the current file that would show (at the least) Name and Alpha/Numeric Codes, and maybe other properties. It would be a great help for our Surveyors to see what the current field codes are.
Does the following post answer the question?
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/189185/alpha-codes
Answer Verified By: Josh M
Yes, perfectly. Thank you very much.
