Hello Folks,
Has anyone experimented with running InRoads SS2 over MicroStation SS10? If you have, what has been your experience?
Thanks and have a good evening,
It's been my experience that IR SS2 is not compatible with MSTN SS10. IR SS2 does not see a compatible microstation product installed during its installation.
This is how we intend on using InRoads V8i (SS2) until we can start all new projects in OpenRoads Designer (ORD).
On a computer with no Bentley V8i software:Make sure CONNECTION Client - version 10.00.19.31 (latest version) is installed/configured - and you are logged inInstall the Bentley prerequisite pack, version 08.11.09.03Install MicroStation V8i (SS10) - version 08.11.09.919 (latest version)Install InRoads V8i (SS2) - version 08.11.07.615 (this version is on SELECT Server license through the end of the year) InRoads V8i (SS2) will have to use "node locked" license after 12/31/2020
We have no problems installing and running these programs on Windows 10 "2004" (x64) We are testing this configuration to see if anything breaks... everything is working "as expected" - so far
Don't forget to modify the InRoads V8i (SS2) command line: Target: "C:\Program Files (x86)\Bentley\InRoads Group V8.11\bin\InRoads.exe" -wsLoad_InRoads_SS2=1
Hope this helps!
