Auto cad references after being attached not displayed after fit view command in open road.
Even the terrain model file attached is not being displayed.
How will i rectify this problem.,
Hi, did you re-project your model by any chance? I am having similar issues with both dgn and dwg references not displaying after changing my projection from GDA94 to GDA2020.
Hi ,
No i have not changed any of my projections.
Can you check your X- and Y-offsets of references? We noticed that the value has changed to "-nan(ind)" on all references that are no longer displaying. communities.bentley.com/.../1f39deaf_2d00_d0a5_2d00_4c9d_2d00_a713_2d00_52307cdb247aAlso just checking, have you checked your level displays?
Levels have been displayed on.
Same References are being displayed in Inroads.
Is this error related to Work Set by any means since i get an error stating " Selected Files does not belong to active work set"
It doesn't sound like our problems are related, let's wait for a response from Bentley.
